1964 4100 carburetor vacuum line not sealed | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter mark dzierzbicki
M
mark dzierzbicki
Regarding the 4100 carb vacuum advance line (steel) , i am not getting a good seal on the carb side.
i'm sure its leaking because the line is not completely tight and the mixture screws were out about 2.5 turns+ (from previous owner) and of course the engine runs rich.
the brass fitting seems to "bottom out " before tightening the line onto the seat in the carb. i have a long list of rejections as to finding a longer fitting or one with a nipple on it to convert to rubber tubing.
even mike's carburetor said no luck because its a double flare .
many thanks in advance for a good solution,
Mark
Why did you title your post "1964"? How is anyone going to know what your post is about? Moving forward, please follow the prompt you saw that ask for a short summary of what your post is about.
I will edit and fix it.
Pull the line out and make sure the little brass cone is still in there.
Vacuum advance doesn't have any vacuum at idle because it's a ported vacuum. You can convert it to a rubber line with the proper fitting and maybe a little thread sealer like Gasoila, just don't give up.
You can check to see if you have any local brake component rebuilders in your area. I'm not sure if I have any of those carbs left. I'll take a look.
