sombb
- Apr 3, 2022
- 1963
Hello,
Working on my '63 Landau, replacing its ancient rag joint (rubber disc) coupler linking steering column to steering box. With the dash and instruments now removed from the car, easiest to leave the steering box in place and detach the steering column into the passenger cabin. One problem: fastening bolt securing disc to steering box is one I've not run into. Attached is a photo.
Can someone identify its type and head size. Definitely NOT Torx. Alternatives I've found via Google: Double Hex, Spline Drive. Other? I need to hunt a socket that will fit. Thanks.
