1963 how do i remove the ignition switch | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter neil willis
N
neil willis
i want to look at the rear wiring on my 1963 tbird ignition switch but don’t know how to get it free from the dash
first do i have to PRY the chrome bezel off
second remove the key roll but then how do i get the actual main switch backwards out
i think the red wire to the coil is brocken
The key must be in the switch, turn switch to ACC side. There should be a small hole in the chrome by the key. With a paper clip put in hole and push in while turning key to your left. Should now be able to pull lock assy. Then you can unscrew to remove switch.
