1963 Generator/Alternator bracket placement | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter FoxyRoxy
FoxyRoxy
FoxyRoxy
7
I saw a photo on a thread that has the tension adjustment bracket in an upper position wich is opposite from where it was on mine before tear down. I have it in tge upper position now. Is this correct?
I inserted your photos into your poat. You can learn how here-
View attachment 13095View attachment 13096View attachment 13097
I have a 61 conv that I am cleaning up from an intake manifold oil leak and I am considering converting the generator to an alternator for posterity. I see kits online for doing this to model years 62, 63 but not for 61. Just wondering what may be a complication for 61? Bracket alignment or electrical upgrade? Any thoughts?
I will be changing mine over eventually but existing generator is working fine with starting and running power. I see you have passenger side coolant lines but looks like plenty of room. Doesn't look like you have a water pump to generator bracket so im not sure how the alternator would mount.
Thanks for the input. I decided to keep the old generator. after all it is a Classic Car. Now I am trying to determine how to extend or modify this tank as it is interferring with the new HEI distributor I am mounting. any thoughts?
Wow. That's a biggin . I don't currently have my tank mounted. I made my own for now while I restore it and the original brass radiator. I think you may get a water neck spacer plate to fit. I've seen them at Summit for chevy sizing so should have one for Ford bolt pattern. While I have ya. Would you happen to have time to take a pic of your power steering lines. Im having trouble re running those. Curious to know what yours has. Nice engine block BTW. 16168614825837124159294489417305.jpg
