1962 Swing away steering engages when in Park | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter sixty2tbrd
S
2
New to forum. I am told that the steering wheel should be locked in place when in the park position. With this being said, why is the swing away engaged when the shifter shows in Park? We have replaced the detent and shifter but still have this issue.
You can only swing wheel away when in park
I was told that in order to swing the wheel to the right, From park you push the shifter past the park detent and then counter clockwise to disengage the locking pawl, in order to swing the wheel to the right.
I lift up the shifter and move the steering wheel to the right and let go of the shifter to lock it there. Lift the shifter lever up and slide the wheel back over. Is that how yours work? Dave
From the "oark" position, we should be able to lift the shifter up and swing the wheel to the right where no gears are available. We then should be able to push the shifter to the left and that is when the wheel should lock in park but it goes right to unlocking the shifter again. So , we cannot get the shifter in Park without engaging the swing away part.
