- Jan 29, 2018
- 1962
Hi, recently putting my 62 back together and plugged in the connections to the original loom. On testing, the rear lights were dim and barely brighter on the turn signals. Looking at the wiring diagram it shows the lamps have earth which would be through the lamp holder through the 'buckets' are alloy and don't conduct. Stuffing an earthed wire onto the lamp everything works as it should. What I cannot see is any earth connection it could of had as the bolts which hold it in are through the alloy so cannot provide the earth. Any ideas?
Also found my 'new' stop light switch is stuck on!
Thanks Andy
Thanks Andy
