1962 rear disk brakes advise? | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter aa010175
aa010175
aa010175
27
I am running ABS disk brakes on the front and drums in the back. They work good. I have a rear disk brake conversion kit from ABS that the previous owner gave to me. I am swapping the complete rear end and want to know if it worthwhile to put the free disk conversion in? Thanks Dave
Have you reviewed the kit instruction sheet as to need to change MC (DISC/DISC), adj. proportioning valve and how to hook up hand brake cables.
Do you have a KIT PN?
Unfortunately I just have the parts. I will call ABS and get kit PN. The previous owner gave me a new M/C as well. I was just wondering if it was worth installing rear disk brakes.
To me personally, I don't see the need as the car will stop fine as designed (1965/67 BIRD with DISC/DRUM). I can see rear disc on say a MUST that you would run on CA canyon roads or a custom car you that can see the brake setup through custom wheels.
But this is your car. You decide how you want to build it.
Maybe when you talk with ABS ask if an INSTRUCTION SHEET is available to help you mount or if you decide to sell the kit.
