F
fasteddy
- Aug 17, 2019
- 1962
I have had 2 cracked bell housings on my 390 engine with automatic transmission. JUst installed the 3rd bell housing and a new starter and the pin in the bendix drops out after starting. A tech manual indicates that the bell housing should have a sleeve casted in the housing for the starter to insert into and prevent the pin from flying out. My bell housing is clean in this area. I checked a 1965 ford starter and it has the bendix gear enclosed, but the drive gear looks to be a 1/2" diameter. The original type has approximately a 5/8" drive gear. I am afraid this will eat up the ring gear with the improper mesh. Any recommendations for a correct starter in this application? Thank you.
