1962 dash lights not working | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter 62sport
6
1962 sports roadster having trouble with dash lights! have power to and out of switch (have tried a new one and no different) and to fuse in and out but not to globes? help! I'm in Aus
Ok doesn’t explain no power to globes when I test them
How does the cluster ground ? Just through mounting screws?
I don't know if Aus is Australia or Austria but yeah sounds like a ground issue.
You could run a jumper from a known good ground to the cluster to test that theory.
If you say you have power coming OUT of the switch are you sure its on the right pin that goes to the dash lights ? If so and the lights don't light there is a broken connection between the switch and the bulbs.. Hard to say more without a wiring diagram
Have you rotated the headlight switch knob clockwise fully to put the dash light bulbs to their brightest? It will help in troubleshooting.
Are you getting power out of the light switch? Often the coil gets rusty and breaks. Check there first.
Then it seems to me that you're holding the problem in your hand. If the switch is not providing power to the dash light coil I would think it is the problem.
