1962 390 FE engine flat tappet lifters?
skorper
Jun 13, 2020
Surprisingly, googling this did not provide me with an answer, so here goes ... Is the original 390 FE engine in my 1962 hardtop built with flat tappet lifters? I ask this because I am trying to figure out which oil to use. Thanks to the many knowledgeable folks here.
yes flat tappet lifters. Should use high zinc oil or add zinc to regular oil that is what i do.
Yes it does, it is not a roller motor.(unless someone spent a lot of money).
I updated your subject to summarize your post.
Yes, use an additive or High quality oil for these motors, I believe Rotella would work also.
