tbird.blue
- 22
- 1963
Hello, perhaps swap the shocks over and see if it makes a difference ? They are quite easy to remove. While they are out you could get them tested at a suspension shop on their testing right. I still feel those temperatures are a bit too far out in the differences side to side. I've checked my 63 and I get same temp on rear and maybe 7-10 difference on the front drums. It pulls up straight as. I initially had the same drama as you when I overhauled all the brakes with all new parts, drums skimmed and new linings indexed to drums. no difference , swapped drums side to side, no difference.Still was pulling hard to the left. Turned out one of the "new"wheel cylinders had a very slight crimp or moulding issue in one of the rubber piston seals for the front brakes. The problem appeared to be the 'made in China' part. ( Even though the catalogue said made in USA!) Another two US made cylinders were ordered and fitted and now all good. Very frustrating ?All backing plate bosses have been smoothed out and greased. All new, quality retracting springs installed. Still veering to the right under braking. I then installed a new right front wheel cylinder as the one just recently installed seemed to be hanging up.
All drum temperatures seem reasonable:
LF 145 RF 160
LR 137 RR 153
But I still have the veer to the right when braking. I re-examined the suspension movement while pulling down on the bumper. The left side hardly moves while the right side has pronounced movement in comparison to the left side. I am believing it is a weak shock absorber on the front right side which may well be causing this. Has anyone else found this condition?
