M
My61bird
- Jan 6, 2023
- 1961
I’ve been going through the brakes on a 1961 Thunderbird I pulled out of the original is barn where it’s been since 1974, and so far I’ve changed two metal brake lines, every soft line, Which were clogged, and every wheel cylinder and bench bled the master I thought it was working, but after bleeding each wheel I’m having problems getting them to work as pressure is coming out when I pump them up along with air and I could feel the front hubs working when it’s up on Jack’s but the rear brakes aren’t locking up and the pedal isn’t coming back up on its own, and while taking a break with a stick holding down the pedal I noticed The front brakes were engaged when I took the break but when I came back they were spinning freely. So is this an indication that my master cylinder is not holding pressure or could I be doing something else wrong?. Thanks for any help.
