1961 Convertible Top electrical Need Electrical shop
M
Jul 19, 2018
I have changed out the solenoids to new upgrade and Top down works rarely. Have checked switches, adjustments etc but cannot get top down! Top goes up without a problem- Is there a shop in DFW that can handle the electrical problems, and possibly the adjustments?
I have changed out the solenoids to ***************** new upgrade and Top down works rarely. Have checked switches, adjustments etc but cannot get top down! Top goes up without a problem- Is there a shop in DFW that can handle the electrical problems, and possibly the adjustments?
I have a ‘61 and it is having a similar problem. Turns out the pump has a leak and doesnt have enough oomph to put the top down. If you are certain that all the relays, limit switches and solenoids are not the problem then check for a leak in the system. Good luck
