John W.
- Jul 28, 2017
- 1960
Does anyone actually have the Bendix "Stop Sign" brake booster with a 1-1/8" bore master cylinder mounted on it? I have been told, and many printed sources say that all power brake equipped 1960 thunderbirds using either Kelsey-Hayes or Bendix boosters had 1-1/8" bore master cylinders, while the 1" bore cylinders were used only on manual brake equipped cars.
In practice, I have found this to be wrong. The 1" bore master cylinders have a collar which fits into the front of the Bendix booster. This collar is 1-1/2" in diameter. The 1-1/8" bore cylinders also have a collar but it is 1-5/8" diameter and thus will not fit the Bendix booster. I have found 1-1/8" bore cylinders only with K-H boosters and 0nly 1" cylinders with Bendix boosters.
My theory is that for 1960 Thunderbird the 1-1/8" bore master cylinders were used only with the Kelsey-Hayes boosters while the 1" bore master cylinders were used on all other applications: both manual brakes and Bendix power assisted.
Can anyone prove me wrong? I'm just trying to get the correct m/c for my 'Bird and it's driving me nuts.
John W. 60 HT
John W. 60 HT
