1959 aftermarket air conditioning control settings | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter 59TBRDMAN
5
I just purchased a 1959 Thunderbird with Vintage after market air conditioning. None of the three knobs on the blower unit are labeled. I know the left knob is on/off and blower speed. The middle is temp. control. I have no idea what the one on the right does. Also the previous owner had no idea how I now run the heat and defrost since the original controls were replaced and covered up by this Vintage unit. Any help please?IMG_20250714_195812779.jpg
How is anyone supposed to know what your post is about when you title it "1959"? Your post title has been revised.
Thank you so much. How do I engage defrost or heat? There is a toggle switch on the under side of dash to the left of blower unit just below the wiper switch. Is this related to this Vintage system?
Can't help with the toggle switch. Read thru the instructions @biddle posted. Note that the system uses water flow control to adjust the heat thru the electronic valve which is controlled by the middle knob. Similar to how Ford did it. Unlike modern cars, it means any changes you make in the setting on the middle knob will take a while to be noticeable, perhaps minutes.
