- Dec 6, 2006
- 1956
Do Wire Wheels fit over disc brakes???
Please
sign in or
join the Thunderbird
If you forgot your password
click here
If you have 14 inch steel wheels that fit over the disc's ok, then wire wheels should not be a problem. Check with the supplier before you buy.Already have them installed.
Are the wheels from Kelsey-Hays? Check with the wheel mfgr. I put Mags on my 55 and installed a set of disks all the way around. I suggest you check also with Wilwood. I do not have their calipers but I do have their master with proportioning block. Another suggestion is to contact Amos Minter in TX and Hills. Both of them do restos and they are usually quite helpful and generous with their knowledge.Do Wire Wheels fit over disc brakes???
