1957 Turn Signal Switch doesn't stay in place when turning | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter dustymtn
D
9
Both the old & new turn signal switches don't stay on like they should when turning. I have to hold the stalk in place. I thought a new switch would solve the problem, but it hasn't. I hope someone has suggestions or a cure - thank you!
Sounds like you might have the cancel cam 180 degrees off. The open gap should be toward the switch when the wheel is straight ahead.
The problem that I had with my turn indicators was that they would not stay in position and would cancel before I would make a turn. This was due to the turn signal plate assembly not holding the roller firmly against the turn signal detent. The fix for this problem is fairly simple and something that most people can do for themselves. Getting to the turn signal mechanism involves removing the horn ring and steering wheel. Once the steering wheel is off you will have access to the turn signal mechanism and will be able to correct the problem.
To remove the turn signal plate from the turn signal mechanism, you will have to unscrew the turn signal arm from the plate shaft and remove the conical spring. The top of the conical spring fits in the groove at the top of the turn signal switch shaft.
Now you can lift the turn signal plate assembly out of the housing. Only using hand pressure, bend the plate assembly so that it will press down harder on the detent when it is reinstalled.
Reinstall the turn signal plate assembly into the turn signal mechanism and install the conical spring and turn signal arm. You can test the turn signal operation by placing the steering wheel on the shaft, without installing the nut. Verify that the turn signals stay in position until the turn is completed. When you return the wheel to the center position they should automatically cancel. Once you have verified that the turn signals are working properly, install the steering wheel and properly torque the retaining nut and install the horn ring.
Working on my 55 horn ring and when I got it off saw basically this. It appears that bolt goes in the place marked. Turn signals work as expected and turn off when turning back to straight. Just wondering if there is a bolt that needs to be in this spot as it is a threaded hole? The turn signal plate does jiggle around a little.
The picture that you attached is the one that I sent from my 1955 Thunderbird. As you can see the hole is not threaded and there isn't any bolt in the hole where the plate assembly attaches to the plate shaft. There shouldn't be any play where the turn signal plate assembly attaches to the plate shaft.
