- Jun 14, 2019
- 1957
I'm going through my brakes to address a hard pedal. I've replaced the master cylinder and rebuild the brake booster. I bled the booster with no problem, but now I'm at the rear wheels and can barely get any fluid flow. I'm using a hand vacuum pump and pulling 15 inches of mercury plus pushing on the brake pedal but I only got a little fluid on the passenger side after a long time and none on the drivers side. My goal is to change out all the fluid (DOT 3). I removed and checked the bleed valve on the passenger side and it is completely open. Am I doing something wrong or is it time for new wheel cylinders? Thanks, Vern
