- Oct 12, 2020
- 1957
Hi, I’m running a Holley 465 cfm on the 312 in our 57. It has 57 jets which appear to be to much as the plugs tend to get a bit sooty after slow round town driving. The motor does not use any oil. The carb has been rebuilt with new power valve 6.5, gaskets etc. and the float level set. The inlet gaskets have been renewed and the heater passage under the carb. blocked and the butterfly valve in the r/h exhaust has been remove. I have fitted an MSD drop in distributor and the timing is 14* advance at idle ( no vacuum) Has anyone had similar issues ?
