![Hernando Muñoz](https://tbird.fordthunderbirdforum.com/data/avatars/m/24/24731.jpg?1662333237)
Hernando Muñoz
- Sep 4, 2022
- 1957
My 57 Ranch Wagon (Y 292) is furnished with a Holley carburetor type "Motorcraft C2TE" original. Gasoline is pushed by a small electric pump located in line close to the tank which feeds the mechanical one that proved to be insufficient but at least moves well the wipers.
The engine starts perfect when cold. But as soon as I shut it down (hot) it won't start easily and must wait around 2 hours.
Float is adjusted so no overflow is seen. But I can see some vapor on the barrels.
I insulated the base with extra gaskets as the separator is original made of aluminum.
The engine runs smoothly after it starts, but I can't shut it down or it won't come back again until cold.
Any ideas of why it won't start hot??
