- Oct 23, 2014
- 1957
I recently purchased a Power Brake conversion from Larry’s T-Bird. Nice compact unit. BUT, the vacuum line routing runs from the back of the intake manifold (along with the fuel pump’s vacuum line) using a new brass adaptor. This connection deletes the ventilation hose that used to go from under the push rod chamber shielding plate. This omission eliminates excess gas and oil vapors from going back through the intake manifold and reentering the combustion chamber. 1957 models were not equipped with a PCV system. What are most people doing with the end of the line that used to come from under the push rod chamber shielding plate?
