1957. Hot coil | Ford Thunderbird club group 1955-2005 T-Bird models
1957. Hot coil
  • Thread starter Thread starter valhalla 4771
valhalla 4771
valhalla 4771
5
Project car has sat a few months. I’m in the process of rewiring everything. Just put in the battery to get it running. Went to check engine compartment wiring before cranking the starter and found the coil was hot to the touch. Not warm….hot. I don’t recall this before I started deconstruction. Is this normal and if not what would cause it?
I put a coil reducer from NAPA 13.00 a mechanic buddy of mine that told me 12 volts makes the coil too hot and eventually will burn out. This reduces the voltage to about 9v. Easy to do just splice it to the wire from the ignition to the coil.
P.S. I have a 55 converted to 12v
Isn't that the purpose of the coil resistor at least on the 57's and also reduce the voltage at the points so they don't burn.
Maybe your resistor went south? I don't know what the ohm's are suppose to be sorry cant help there. Also I went with the Pertronics electronic IGN and a new coil.
I've also installed Pertronics electronic IGN and coil, can't say enough about the positive effects (engine temp, idle, fuel mileage ). If you do go with Pertronics you should eliminate the Ignition Ballast Resistor.
Some pertronics units still use a resistor and the original resistor will work.
Perhaps your using a Pertronics II
Ford continued using 6 volt coils through the sixties. The 12 volt wiring initially had a ceramic ballast resitor and later an inline reducer With Pertronix you bypass the ballast resistor and use a true 12 volt coil
It was my understanding you did not use the resister with the Petronix ignition module????
I have a 55 T-bird with a 6 volt system. Is it a good idea to convert the standards point system to a Petronix ignition system?
Pertronix can and do work on both 6 & 12 volt systems. I'd suggest calling the Pertonix customer service & technical support to be sure they have one that works for your specific application. 909-599-5955
