1957 Gas Overflowing Out Filler Pipe | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter dustymtn
dustymtn
11
While sitting for a few weeks during this winter, gas starts to overflow out the filler pipe - twice. It happened last witer as well. What could cause it to happen all of a sudden?
The gas line has a steel breather line back to the tank level to allow drop in pressure to let you fill in faster. My 57 is a pain in the rear to fill. I made sure this line was open and it was. Still, I have to fill it slowly. There is also a rubber line at the bottom rear of the tank that can split open. Make sure this line is in good shape.
Like/Thanks Posts
Thanks for your reply. The wierd this is that it's leaking out between the filler tube between the tube & the gas cap.
On the 56 bird years back, the new ethanol gas ate up the rubber line from filler to tank. Had to boil out tank, clean line to carb, and the carb. It was a disaster!
Sounds like the gas is expanding and forcing it's way out of the gas cap. Is the tank full when this happens? With a full tank on a warm day this can happen.
The vent line from the top of the gas tank goes to a few inches below the gas cap into the side of the filler tube. It's possible where the tube is brazed to the filler tube is has cracked and leaking if the take is quite full.
Just FYI, early 57's had a vented gas cap and later ones had un-vented. I didn't know the difference until gas was all over garage floor.
I have never heard of them using unvented. There was nothing different about the gas tanks or fuel system between early and later 57's that I have ever heard about.
Like/Thanks Posts
Thanks for all the responses! The leakage is happening over the winter in a cold garage. It's a weird phenomenon. I may have to figure out a way to only fill it 3/4ths full.
