C
calbears
- Sep 5, 2014
- 1957
With the ignition on, the gas gauge only slightly moves from pegged on the empty end to about the empty mark. The gauge needle moves about 1/8". There is about 1/2 tank of gas in the gas tank. I checked the gauge by grounding the wire that goes to the sending unit in the tank. The gauge goes immediately to full, so I have read the gas gauge is not the issue. I took the sending unit out of the tank and grounded the unit while still plugged to the wire to the unit. I could manually move the float arm and get an empty reading on the gas gauge at the empty position of the sending unit and about 7/8 full at the full position. I reinstalled the sending unit and again, the gauge just moved from pegged to empty. I then taped the sending unit arm in the full position. I reinstalled it and the gauge shows about 7/8 full. So, the sending unit is grounded okay but it appears the float will not move to register the gas level. I then checked to see if the float would actually float. I put it in a bucket of water and the arm moves as the float floats. As the sending unit did not seem to work properly, I took it apart to see if there was some internal adjustments. Yes and no, but either way, I put it back together and it doesn't really work anymore.
I then bought another sending unit hoping that this would solve the problem. Pretty much the same as above as the gas gauge only slightly moves when the unit is installed. The only difference from the first sending unit is that I have the new unit out of the tank and manually move the float arm to the full position, it will only read about half full. I have read bending the float arm may help but I have not tried that yet as there is no use bending the arm if the gauge will not register with the sending unit installed.
My only thought is to completely fill the gas tank and see what, if anything, happens. It seems futile as there is certainly a fair amount of gas in the tank. Any other suggestions?
