- Feb 14, 2014
- 1957
Well, my next project is replacing the weather-strip on the door. I bought the Daniel Carpenter weather strip as I have read that it's the best. My driver's door when closed sticks out 1/8"+ and I keep getting comments that my door isn't shut. BTW, I have adjusted the latch to a point I have to slam the door. Sooo, the weather strip tears off but leaves fragments and adhesive. While the weather strip seems surprisingly soft, the adhesive is like rock hard. I have tried Goo Gone commercial grade, 3M cleaner (I don't care that the adhesive ends up clean), 3M remover, and a heat gun gently. I work on it for a little while each day because it's miserable! I'm not happy with what I've done so far but now I'm at the front of the door. Being close to the fender and the hinges are in the way, does anyone have a trick to access this area? (No I don't want to remove the door)
