KellyLyons
- May 11, 2023
- 1956
I have recently purchased a '56 Thunderbird, 312 & Fordomatic 2 speed auto. The car has been in Australia since 1996 and was converted to right hand drive by a previous owner in the US prior to arriving in Australia. I noticed when test driving a couple of things about the shift lever. While I have owned other classic cars, I am a new first time owner of a '50s Ford, so would like to clarify some things.
1. To start the engine the lever must be slightly moved rearward out of Park. Is this common?
2. Once started to move the lever the button on top must be depressed and moved past Neutral and Reverse into Drive. I am happy with that.
3. When parking, after the car is positioned, keeping my foot on the brake, I noticed I did not need to depress the button again to move forward past Neutral and into Reverse. Does this mean the detent in the mechanism is worn? and needs some attention? Or will it go from Drive to Reverse without using detents?
My main concern is... could the shift lever accidently go into Reverse when you least want it to?
The photo shown is not of my car but one from the net. When the car was converted the shifter position remains unchanged ie: still in the LHD side of the tunnel.
