K
kerry a berg
- 2
- 1956
Replaced front drum brakes with disc brakes nearly 20 years ago with by brake vendor. I just rebuilt brake power booster and observed that the power booster was connected to the rear drum brakes. This does not seem right as front brakes generally supply 70 to 80% of braking. I’m want to change that. Can I go from master cylinder (dual bowls), to brake power booster, to proportioning valve, with the two forward lines of porortioning valve (large bowl master) to front disc’s brakes and rear line of proportioning valve (small bowl master) to rear brake lines?
