J
jay089
- May 7, 2022
- 1956
Please
sign in or
join the Thunderbird
If you forgot your password
click here
The screws are instlled into the fiberglass. there are no captive nuts or other attaching points to screw into except hoes drilled into the top. Be very careful. is you ust drill use a drill stop. it is too easy to go too far and then need to patch the top. There several tools available that include a shallow drill bit and combination easy-out. I recently had to do this on another project.What is the best technique/solvent to get the rusted screws out of the hard top? I was able to scrape away of the old weather strip but cannot remove the old screws,
If the heads are rusted out and you can’t use your screwdriver you might have to drill the top off the screws and use pliers to unscrew the remaining screw or you might have to drill new holes? Have you tried penetrating oil?What is the best technique/solvent to get the rusted screws out of the hard top? I was able to scrape away of the old weather strip but cannot remove the old screws,
