FERENC
- Dec 10, 2019
- 1956
Good day to all,
Doing repairs on my '56 and have come upon an item that I could use some information on.
The grille was only attached at the bottom, to both the lower grille opening molding and then through the front gravel pan, as well as on the Left & right side ends...
There were no fasteners at the top - it was vertical and the top tucked into the front reinforcement bar behind the header panel..
However, on the reinforcement bar, at app. 30 or so degrees downward on the bar flange towards the rear of the car - there are box nuts, that do line up with the holes on the top grille flange.
How does the top of the grille fasten ? - if so - to the reinforcement bar - is there another angled bracket? A bit stymied here
Thanks inf advance for the help & discussion.
Image for a bit of reference.
