- May 1, 2020
- 1955
I am having difficulty finding a suitable replacement speedometer Cable that will work with existing Angle Driver. The current Angle Driver appears to have an Extension on it which doesn't resemble the current offerings of this part, The Transmission side of the Cable which screws into this Angle Driver has a 1/4" flat driver piece which can be removed from the Angle Driver end, the new Cables offered do not match up with this Fitting so the next approach was to replace the Angle Driver and the Cable which compatible connections however the current extension seen in these images is throwing me. Has anyone information on what the best approach would be? I am attaching images of the Angle Driver that is attached to the Transmission.
