1955 T-Bird 292 Intake manifold thermostat housing crack
zeroroadkill
zeroroadkill
BlackBird Fly
Mar 2, 2020
I decided to change out the thermostat to the 170° wide opening thermostat. I found that one of the thermostat housing bolt wasn't too tight but didn't give it much thought because the previous owner had replaced the 180° thermostat with a 160° thermostat not too long ago. When I tried to torque the bolts per the manual I noticed now wouldn't tighten up, this is not good I thought, then I noticed a piece of the manifold pop off!!!:oops: See picture.
The original bolts are 7/8" long so I bought two 1" bolts hoping that the remaining threads in the manifold will hold tight.
My question is: since this bolt hole backups up the intake port for cylinder #5 would it be possible to utilize the wall material to create a few more threads by drilling through the intake wall, tapping and install a measured bolt for the thermostat housing that would stop flush with the inside of the intake so as not to interfere with airflow?
I thought of welding it but this is sketchy because cracks can be formed and water leaks would be critical in the manifold. The only other option is to replace the manifold...:(
Thoughts???
Thanks
Bob
Model year added to subject.
I inserted your image into your post. Here's a howto for reference-
If replacing the intake manifold is truly your only option, then what have you got to lose. You might look into a helicoil although that would require a larger hole. Perhaps filling the hole with something like JB Weld then drilling and tapping the new hole. At any rate good luck to you.
Install a stud, not a bolt. Use JB Weld or similar to lock it in and hold the broken piece in place.
If the longer bolt doesn’t work this was going to be the next step.
Thanks
Thoughts???
Thanks
Bob
Replacing it is the only option. If you can’t find one, or care about originality you can go with an edlebrock or other aftermarket.
I know. Hate to modify it tho. If that’s my only option then I’m replacing the carburetor and replacing the distributor with something more modern then and the air cleaner:oops: I hope it doesn’t come down to that I like it being original. I found two on eBay but no response yet $300 and a NOS one for $675:eek:
Does anyone know what the stamp 56Q means below the manifold model number? The replacement is a 54E.
@zeroroadkill if you purchase on ebay.com, use this link and our club gets credit for the purchase at no cost to you. Thanks!
I had that hate to modify thought for a while, then realized my car would never be a perfect specimen. The new carb and distributor were a huge improvement, no regrets. Now I'm cutting loose and installing disc brakes.
What did you do about the tach? It’s cable drive.
