1955 Rear Shocks replacement difficulty | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter deandup
deandup
deandup
How difficult is it to replace the rear shocks on a 1955? Can it be done without a lift.
Yes, it can. You'll need to jack up the rear of the car so you can get underneath. Place jack stands under the axle - the axle needs to be supported. They are then easy to replace.
… the axle needs to be supported…
Wouldn’t that depend on whether the shocks also had helper coils? (easier than replacing/re-arching worn leafs). I place ramps under the wheels for access after lifting the axle, then jack up the frame if needed.
Your subject "1955 Rear Shocks" has been revised to summarize what your post is about.
I just did mine. Had to cut them off, may have been the original. 30 year old verified from the previous owner. No jacking or tire removal.
