cmcphail
- 2
- 1955
The 292 engine in my 1955, which has not been started for about 10 years ejected a small separate lower layer of green coolant when changing the engine oil.
I am not a mechanic, but a DIYer.
To diagnose the leak, I used a boroscope to examine the pistons and there was no sign of rust and the cross-hatching was intact. I put a pressure tester on the cooling system at 10 psi and found a drop in pressure within 15 minutes.
As the first stage in removing the heads, I removed the intake manifold and tappet valley cover. I found that there was both oil and green coolant in the valley.
is it possible that the coolant in the oil is only due to a slow gravity leak from the intake manifold or thermostat dripping onto the tappet cover, passing between the bolts and the grommets on the cover and and entering the valley, making it's way to the crankcase? Would pulling the oil pan provide any confirmation?
Also, since a bad head gasket is a more common root cause for coolant in the oil, would you pull the heads anyways?
