1955 adding passenger side mirror | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter spierssn
spierssn
spierssn
I am looking for advice from you guys with experience. My 1955 has only a driver side mirror. I am at the age where I have great trouble trying to swivel far enough to watch my rear fender when backing up. I am considering 3 alternative "old man" ways to avoid things such as my garage door.
1. a rear camers.
2. side view cameras.
3. new door mirrors.
I hate to drill holes in my doors for mounting door mirrors, the rear camera's seem to see more of the area behind and not so much at the side & the side mount cameras spoil the babybird lines. Any advice will be greatfully recieved.
Thank you
Simon
If you drill on the passengers door to mount a mirror mount the mirror a little past the A Pillar, Do not mount exactly like the drivers mirror . If you do the A Pillar will block the view when you need to see. Don't ask me how I know, It's from experience.....
1. a rear camers.
Thank you
Simon
I your car had a 12 volt conversion done, you could always install a wireless backup camera without drilling any holes. I installed a Auto-Vox wireless backup camera on my 2004 Thunderbird. I thought that the intallation was quite easy.
As Icon said, choose the location fore and aft wisely. If possible have someone hold it in position while you sit in drivers position and have them move it fore and aft till its in the perfect spot. Some folks put removable painting tape on the door to protect the paint while doing this and also to mark the screw holes when you get it in the position you like for drilling.
They make convex mirrors which you may find more useful on that side instead of a flat one.
Great advice ! I should have had a helper do this but being excited about getting a new toy I made a mistake, Now I have to live with it..... Lesson learned.
I found a convex mirror very close to the same diameter as the driver’s sideview mirror and attached it directly to the original. It’s hardly noticeable and makes all the difference in the world, at least on the drivers side. You may still want something on the passenger side, though. Hope that helps. Good luck!
T-Boid Mark
1. a rear camers.
Thank you
Simon
I am of the same age and problem so fitted lookalike mirror and it blends in well. Got my wife to hold the mirror while i sat in car to ensure view was good and then got out and marked two holes, its not a big deal really. You can source mirrors at all t-bird suppliers just find one that matches yours
Agreed! Also there are so main bad repros out there, that only after you open the box you find the darn thing has a shorter swing than needed. If you want that type I've got two I'll give you. Just get a buddy to move the mirror with you behind the wheel to get it perfect. You really won't notice the mirrors are ofset from each other.
Ya I mounted a passenger’s side mirro on my 66 t bird landaur the blind spot are horrible no back side windows, but ya I put one on but it was wrong year I think a 65 oops, there around 75 bucks a shot,extra for the bird symbol, any way I kinda just lined it up with the rubber water proof seal it came with and marked it with a marker drilled 2 starter holes and used the to self tighten screws it came with, it loosened a little now and then, I should of used some lock tight on it, also when slamming the door it seems to lose it adjustment so you need to lean over and adjust it now and then
