- Mar 2, 2020
- 1955
Carb professionally rebuilt
New gas tank
Flushed fuel lines
New fuel pump
New fuel filter
Max vacuum at idle
Sometimes she will start out ok acceleration but today after all the fixes she started to stumble at 40mph on smooth acceleration. Had to pump her to keep running. Then she ran fine! Sounds like fuel delivery to me???
Checked float level = ok
Fuel filter bowl full
No debris
another problem is when she sits for a couple of days she is hard to start. Initially a couple of pumps she’ll fire but die and it takes a lot of cranking to get her started. Usually have to use ether. I assume there is fuel at the accelerator pump but maybe the float bowl is empty? The fuel filter bowl is full. Need to check float bowl before next try.
any suggestions?
New gas tank
Flushed fuel lines
New fuel pump
New fuel filter
Max vacuum at idle
No debris
any suggestions?
