'57 wide whitewall tire inserts
Ward 57
Well-Known Member
Has anybody used the wide whitewall tire inserts? I had to replace all my tires due to age ( cracking, splitting ) etc.. I was moving and needed new tires in a hurry so bought some cheaper tires ( needed all 5 ) with the thinner whitewalls and I just can't get them white as new. just clean but not white. Any experiences? It may also be a good time to clean & paint the wheels so they are all body color also as they should be. Oh they are radials if that makes any difference. A driver not a show car so authenticity is not an issue.
If you use sand paper, (start with a lesser aggressive grit) that will usually bring back the white
Ward 57
Well-Known Member
I think you guys are missing my point. I don't want to clean my current whitewalls but put on aftermarket white wall discs that go between the tire & wheel. for $75-$110 per set of 4, seems pretty practical to me if they work.
1957Bird
Well-Known Member
Funny
That’s exactly what I thought you were referring to. Back in the day they were called “Porta Walls”,I wasn’t aware that the were still available. Hell my father used them on his 54 Buick.
Rentman
I had no idea porta-walls were still around. They looked great on my 50 Chevy with the rims painted red and moon spinner hub caps. The only addition to that hook up were curb feelers. You really have to get a good seal between the rim and tire or else the porta-wall will pop out and look like your tire has a blister
Ward 57
Well-Known Member
Oh yah, they are still around. I did an internet search for wide whitewall inserts and they we one of the first to pop up. So you had a good experience with them?
Rentman
The experence was good but you had to make sure the bead of the porta wall was secured between the rim and tire or the porta wall would budge and your cover of having real white walls would be exposed......... speaking from experience. Man that was 65 years ago but I do remember the porta walls making a $10.00 used tire look great
Ward 57
Well-Known Member
I think I'll go with the porta wall 2", I don't see 2 1/4 only 2"& 3" . They are now only $49 with free shipping, they used to be $75.
Ward 57
Well-Known Member
I wouldn't use a porta-wall with a tubeless tire.
For $45 I'll give it a shot plus the cost of mounting. It couldn't be worse than the almost invisible white walls that I have now. I'll let you know my journey as I know there are a few others who are considering going that way on here. I'm sure over the years they have figured that out.
Could be the most expensive 45.00 you will ever spend
Ward 57
Well-Known Member
With thousands of users very happy with the results over many years? With all the questions of wire wheels and tire sizes It's a minor issue. What is your objection? Been there done that? Let me know your real life experience. Are you willing to spend $600 on period correct tires to prove a point when the ones I have are capable but look terrible? That's why we have so much cheap foreign crap to save a dime. For $45 I'm willing to take the chance on the mistake I made but under time and financial restraints I don't question my decisions.
