1970 door lights and rear interior lights won’t extinguish | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Drain70Tbird
Drain70Tbird
Drain70Tbird
1
The door lights and rear interior lights in my 1970 T-bird won’t extinguish. Is there a door switch or something I can check?
First check the headlight switch. I believe if you turn it all the way left it makes your dash lights brightest, and past a notch makes the courtesy lights come on.
Otherwise check the door switches, simply disconnecting them will tell you if they are the problem.
The first thing I tried was the light switch, and then tested all the fuses in the glovebox- no dice. When it cools off this evening, I’ll pop out and check the door switches- had to d/c the battery, in the meantime. Fingers crossed, hopefully it’s a bad switch. Thanks for the reply!
