Rat Fink
- 2
- 1969
Hey, fellow 'Birders'!
-After oh, 4yrs or so, I yanked the $350.oo+ 4bbl Edelbrock (read; 'Carter AFB') '750'series carb OFF my '69 bird (429c.i.), & went ahead & put the 'Fac.-stock' Autolite 4bbl back on. ( Yeah, I SHOULD'VE gotten a '600-'series which is more for 'Fac.stock' Big Blocks...).of using WAY too much gas,
My problem is; "How does one set the IDLE on this thing".?! -ya got your 'normal' throttle-linkage on carb's left side- BUT it's got yer 'IDLE-ADJ'. screw -and this wackey-assed 'floating Choke' bakelite 'flapper' thingie (with tiny adjusting screw) on the OTHER side, which has to 'Sync' with the Round, 'Spring/heat-riser tube' operated 'normal' Choke-plate Adjust.
The 'CHILTONS' manual (carburetor(s)-section) only deals with your various 'bench Re-build' pre-settings (float-drop,etc.) & to; "set 'choke; 'one-rich' ( 1 notch back from 'center). - It says NOTHING dealing with FORD 'factory' 'on-the-car' tuning/idle adjustments..!
Can anybody >HALP?!<
- having trouble getting it to 'hold an idle',('rough' & 'Lopps') -where with the 'Carter' carb, idle was nice 'n' smooth... -No Problem..!
