W
waymilky
- 1
- 1966
Recently my drivers power window quit functioning. The motor runs and sounds normal, but the window does not move. The window can easily be raised or lowered by hand. I took the door panel off and took a look inside using mirrors. When the switch is used the motor runs, but the small gear attached to the large flat gear does not turn. When I raise or lower the window manually, both gears turn freely. I thought about trying to take the whole motor/regulator mechanism out, but thought I would seek advice from someone with experience. If I do need to take both the regulator and motor out, do I do that by disconnecting the regulators from all four rollers?
Looking in the Bird Nest catalogue I see they sell some sort of " gear repair kit." It looks like there are at least two bolts that attach the motor to the regulator. Are there more than two?
Any advice is appreciated.
