1965 seat belt light & brake light problems | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Mr. Kelly
Mr. Kelly
Mr. Kelly
3 Problems need help - - I have a 1965 Special Edition Landau. - - Problem 1. When I step on my brakes my right-side front turn single light comes on. - - Now when I step on my brakes or even rest my foot on the brake pedal both turn single lights come on. Don't know where to start. - - Problem 2. Seat belt sent into Safety restore in Westfield MA. they put a new Re-Web strap on and sent it back. -- plugged the power back in when I pull the seat belt and put it on the light stays on. - - Problem 3. Left side power window new motor. Now no power to motor. fuse is new and ok.
Well for the signal issues first check all of you bulbs. If they are all good then you have bad grounds.
For the seat belt you may have to take it apart where the wire connection is and check them.
For the window start at the motor and work you way upstream with a volt meter. You may not know that to check for power at the motor connection you need to have you volt meter on both wires. Your window switch switches the power and ground between the two to give up and down.
No need to include "Thunderbird" in your subject. We are an all Thunderbird site. I also updated your subject to summarize your post.
