1965 brake caliper installation | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter bopaho
B
I bought a set of brake calipers, they were a 1 piece caliper, when i removed the drivers side caliper from the front of my 65 Thunderbird, the outside cylinders came off , leaving the inside cylinders still connected, i cannot figure out how to remove it without removing some of the steering components, the caliper comes in 2 parts
How is anyone supposed to know what your post is about when you title it "1965"? Please follow the posting prompt directions moving forward. Your title has been revised.
It will be bolted (2 bolts) to the spindle from the back side.
If you “split” the caliper (pistons in both halves?) it will go back together but may require “0 rings”. Then will have to be bled.
