projo198
- 10
- 1965
FINALLY got the 65 running this weekend only to discover a tapping on the passage side and lots of smoke on that side's exhaust.
Found this issue on cylinder 2.
I manually manipulated the valve there and there wasn't any resistance besides what the spring provided. Originally I was going to just replace the rod and see what happened, but now I am going to do a leak-down test and see if there is anything I need to worry about.
If the valve had just temporarily locked up enough to bend the rod would a bent rod like this cause the smoke? I believe it was white smoke (which leads me to a possible head gasket) but it was cold outside so hard to tell.
