1964 Valve lifter noise. | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Ezdarryl58
Ezdarryl58
15
Well fired 64 bird up first time after 20 yrs . Have alot valve lifter noise which i know is just a norm for most fords. Is there any additive i can add to lubricate and quiet it down.? All fluids changed . Just trying to prevent pulling heads . 40.000 original miles . Any input would be greatly appreciated.
For Hydraulic lifters go to Walmart and buy a quart of Marvel Mystery Oil and put it in your crankcase and run it for 30 days. The more you run the car the better the car will run. It cleans the lifters out so that they can pump up completely. A friend of mine had lost power and the valves were terrible noisy. He was going to change his engine but after 30 days he was very happy. Needless to say he did not change his engine.
Please include the model year in the subject line on future post. I have added this for you.
Thanks . Never thought about marvel
Realistically, I think there are a lot of Flair Birds out there but we don't see them because they don't run or are rusted out old hulks🙂
I have the same experience at car shows by the way. Tend to see roadsters a lot but rarely Square, Bullet or Flair Birds.
Have you dropped the pan? That should have been done before trying to fire it up the first time. Get any garbage and sludge cleaned out.
After that, you can try various things to clean the lifters like Marvel Mystery Oil and ATF. I have run 4 quarts of ATF with a quart of oil in engines in effort to clean the valvetrain. Just let it idle for an extended period and don't put the engine under load. You could this a few times depending on how dirty the drainage is.
This is a bit of a long shot but it could save you the labor of pulling the heads and replacing the lifters.
Dave
Absolutely the above. this MMO will remove sliduge and cure clattering lifters in many cases; I've used it for decades.
Here is my 20,000 mile 2002 TBird last fall on cold startup - 200 miles with MMO and the noise is completely gone:
I wouldn't pull the pan, unless you have a serious leak, or you intend to rebuild the engine. Other than the lifter noise, how does it run? Even my 2017 Ram 1500/10,000 miles will have lifter noise after sitting for a couple of weeks. It clears up once it's been running for awhile. Of course, it has roller lifters.
As far as your replacing the lifters, finding quality-replacement, flat-tappet hydraulic lifters is easier said than done.
