- 28
- 1994
I have a weird problem with the fuel gauge on the '64. it was reading erratic, so I bought and installed a new sending unit, made sure the ground was good. Checked and substituted a constant voltage regulator, still the same problem which is: start the car, gauge goes to 1/2 tank which is likely correct for the fuel in the tank. When I turn the car off, the gauge stays at 1/2. If I open the line isolator I installed, the gauge goes back to 0. Happens every time so somehow, there is a voltage retained to keep the gauge at 1/2 tank reading.
Any thoughts? I installed the isolator as I am lately having a leakage problem, small current, about .42 amps that drains the battery over two or three days. But i cannot determine if that somehow contributes to the gauge problem.
