1964 convertible top tension spring installation | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter plto6
P
Hi
Were there tension spring on 64 convertible top, if so where are the connecting points and did the cable go in the top or the top pads. a picture of the connect points would be helpful
Thanks
Boyd
There's a thread about this here: Convertible Top Installation
I made the springs (actually, elastics) using bungees and ring terminals from Home Depot. This was three years ago and they've worked great and held up fine. I made tension cords using parts from Home Depot. The bungee part is a tarp stay cut to about 13-1/2" (cutting one stay in half yields enough bungee for both sides). The ends are 12-10AWG ring terminals meant for attaching wires to posts. I pulled off the insulation, used needlenose pliers to spread it enough to get the bungee in, closed it back down with the pliers, then crimped it using a crimp tool meant for electrical terminals. The results seem good but I guess I won't know until it's all together. The bungee in the tarp stays is 3/16" which is a little smaller than the 1/4" you used but it looks okay and fits the ring terminals well. I'm not sure if the tension is right; if not it's pretty easy to re-do them.
The Body Engineering Trim Manual has a good view of how the top of the curtain attaches to the bow on page T6-4745, sectional view CC. It loops around a rod (also missing on mine, yet another trip to Home Depot) then folds back on itself. The rod is then clamped in place by the retainer.
Thanks for the dimensions on the tensioning cords. I made mine way too short (13") but fortunately it's trivial to make more and the bag came with six tarp bungees.
My tack rails are not in great shape but I wasn't able to find replacements. I cleared off the rust as best I could with a wire wheel then sprayed them with Rustoleum Rust Reformer to try to stop the decay. We'll find out shortly if they hold up. The ones on the package tray are the most challenging since they have a complex set of curves to them and aren't just wrapped around straight like on most cars.
Thank you so much, does anyone know if you have to make attachment points to connect the tension springs? are they already there, I don't see any on mine
I got my top and tensioning springs from Kee but done not see any place fro the springs to run.Does anyone know where to run the spring ? Does it run in the top or pads. also I can not find where to connect the springs to the top frame
