PLtex
- 0
- 1964
The brake lights on my 1964 won't activate when I press the peddle. They do light up when I turn on the headlights and seem to work ok when the turn signal is activated. A friend suggested that I start with two low-cost likely brake light culprits: 1) a switch which I believe is mounted near the brake peddle, and 2) a relay under the hood hiding behind the washer fluid bag that may have something to do with this year not being equipped with the sequential turn signals that started in 1965. Thought I would see if others here have any insights. By the way, when I look for replacement parts, it seems the 64's have some different parts for braking system than the 65's and 66's which makes things very confusing for a novice. Feel free to reply like you're talking to someone who isn't very familiar with this model (cuz that's me at this stage). Thank you!
