ak7an
- 81
- 1964
Like I stated in a previous post have the dash all disassembled to troubleshoot a few issues. One issue I am working on is my HVAC controls. Nothing in the system will function quite right, everything is trying to open and close as I change the control position. I am only able to hold between 10 and 11 inches of vacuum, and whwn Increasing RPM's a bit my test gauge will go to around 17 but fall back to around 10 at idle. Tested the check valve and it is working as intended. When I disconnect the HVAC control at the fire wall I get and hold 18 inches. So here is what I did to try and see where I was losing vacuum.. I disconnected and plugged off all the small lines that go to the vacuum actuators.. still same, can only build and hold around 10 inches. So to me it would seem that the control unit itself is leaking somewhere. Is this a common issue with these old units? Are these repairable, or will I need to find a working replacement?
Thanks
Ed
Thanks
Ed
