1963 Ignition Switch Removal Tips | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Lizzy
Lizzy
9
I need to replace the ignition switch on my 63.I put the key in and it wouldn't come out and the ignition is in the on position.Had to shut it off with the coil wire..Do I need to take the cylinder out before I remove the switch.And what is the best way for a novice to remove the switch.I have the shop manual but any suggestions would be helpful
Please follow the instructions when posting in the future. Your subject "Ignition Switch" has been changed to "1963 Ignition Switch Removal Tips"
Yes, the cylinder has to come by using the key, most of this era's cars have a small hole next to the key slot...turn the ignition to the far left and with a paper clip in that small hole you should feel a pin with spring pressure when you push in on the paper clip. Keep pushing on that while turning the key farther to the left. Withdraw the cylinder using the key at this point.
That should get the tumbler cylinder out then you can remove the switch body..
As Frankie states, note its a bit of a fiddle though. I've done this a couple of times a few days ago, the first time was hard but once you realise the pin you press in doesn't need a lot of force, the lock can be turned anti-clockwise and pops out. It the Aux position you need when pushing in the pin.
Okay Folks… You have now told us how to remove the ignition lock cylinder
Now if that is ALL you need to do then just insert your NEW CYLINDER and your done
BUT……
If you’re changing the actual ignition switch
Get a 5/16 out to remove the nut on the back of your ignition switch under the dash
Wires are free now
Place a large slot blade screwdriver on the spring towards the front of the cylinder switch
Push on the spring and Voila
The Ignition switch will fall out
Now reinstall this in the reverse order
YOUR DONE
