1962 stuck valve, no compression in 2 cylinders | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter fcurto
F
1962 how to fix a stuck valve and 2 dropped push rods (no compression in 2 cylinders)?
can anyone explain how to fix this or send a video possibly?
Had the engine been sitting for awhile and this happened at first startup or how did it happen?
READ THIS -
READ THIS -
Thank you. This is actually for a 56 tbird, the title has a typo on the year. Yes the engine has been sitting awhile, any idea how to fix this?
Check to see if you can push on the valve manually to make sure they're not stuck. If they're stuck manually oil the valve stem at the guide and tap on them with the wooden handle end of a hammer. Other thanthat and if the valves are just plain stuck your gonna have to remove the head. A lot of collectors will start their car once ina while, let them run for a few minutes only and shut it off.Oil will not get to the guides and will eventually cause this problem. My answer is DONOT start your engine until your ready to drive for 20 minutes or more.Then the engine goes thru normal warm up and oil circulation.
It is a 1956 BIRD 312CI FYB?
READ HERE - http://forums.*******************/Topic17309-1.aspx
Ethanol laced gasoline if left to sit turns to a varnish and fouls the valve guides (and other components) causing the valve stem(s) to seize, especially if left to sit for months. In addition, the FYB push-rods are solid which makes them more prone to bending and throwing (weaker than tubular push-rods), which may be a good thing as a safety feature in this instance.
You need to shoot a good penetrating oil at the valve stem(s) and allow it to penetrate say over couple of days. Tap the stems (only) with a brass drift lightly to help free up. Don't pound. Perform this for a few days, install new push-rods (better tubular) and turn engine by hand before firing to see if all valves are free.
If you tap the valve to include the spring retainer, it may cause the valve stem locks to fall out.
Putting a car to sleep over the winter is the worst thing you can do to it (IMO). At the minimum, use a QUALITY gas stabilizer with a full tank of gasoline (double up on the amount). Ethanol laced gasoline is hydroscopic drawing moisture from the air (as also does brake fluid). The full fuel tank will slow it down (absorption) somewhat but is still vented to outside air (pre-EVAP).
At a certain percentage, absorbed water (moisture) will separate from the gasoline and sit on the bottom of the tank. Some early tanks had a bung whereas you could install a petcock and drain the water periodically.
If possible, disconnect the gas inline tube @ the carb (or fuel pump inlet), block it and allow the engine to burn what fuel is left in the carb. Let it draw a mixture of fresh gas and SEA-FOAM (In a container to protect the inside of the carb during storage). The ethanol will also foul a mechanical fuel pump and the gas tank.
Before spring firing, replace the fuel filter. A paper fuel filter will deteriorate over time with ethanol.
