1962 generator vs. alternator | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Bird Giril
Bird Giril
The guy that owned my ‘62 before me replaced the alternator with a generator, is it going to be a problem? Should I have it changed back to an alternator?
An Alternator is a prefered choice but if the generator is working then just add it to the 'to do job' list!
I’m sorry, I’m new at this forum thing… what do you mean add it “to do job” list?
It actually isn’t working too well, the battery has died on me a couple times.
Alternators charge more at an idle, however if the car originally had a generator I would leave it alone.
If you want to test it put a voltmeter across the battery and at about 1500 rpm you should get between 13.8V and 14.2V.
If so the generator is not your problem; if its much higher (e.g. 16V) then it is "running away" and has lost regulation.
Much less and the generator may need new brushers.. I ran a generator for 10 years (factory) on my 61 Corvette with
a 750 Watt stereo amp in the car and never had a single problem.
Why do you say it originally had an alternator? Alternators weren’t put in Fords until about 1965. Is it your contention that he converted everything to make the alternator work and then devolved back to a generator?
Bird Giril,
Nothing wrong with a generator. It how they originally came in 1962. I believe the alternator was first offered on the 1963 Thunderbird. Assuming that the car was at some point successfully converted over to an alternator, my concern would be that someone just plopped a generator into existing circuitry designed for an alternator without changing out the voltage regulator and wiring. That would be a problem.
The charging system consists of the battery and cables, the alternator or generator, and an external voltage regulator. The function of the battery is to spin the starter motor to start the engine. Once that’s done, the alternator takes over, satisfying the car’s electrical demands and keeping the battery charged. The battery then acts primarily as a filter, keeping voltage spikes from damaging the car’s electronics. The voltage regulator rapidly switches the alternator in and out of the charging circuit to provide the car with the correct voltage.
In 1955, the electrical system of the Thunderbird was 6 volt positive ground. In 1956, the Thunderbird electrical system was changed to 12 volt negative ground. On the 12 volt system there are two important numbers to remember, they are 12.6 volts and 13.5 volts.
12.6 Volts: If you think your car has a 12 volt battery, it doesn’t. The 12 volt battery actually has six individual 2.1 volt cells (one under each fill cap). Thus, when fully charged, the battery should have a resting voltage of 12.6 volts. If with the engine off, the resting voltage is less than 12.6 volts, the battery is low and needs to be recharged. Of course, it begs the question of why the battery is low. It could be that the alternator isn’t working, or that the battery has reached the end of its useful life.
13.5 Volts: With the engine running, the alternator should output a charging voltage that’s about a volt higher than the resting voltage, or about 13.5 volts. The exact charging voltage may be as low as 13.2 volts or as high as 14.2 volts.
If your Thunderbird is a 1955, with a 6 volt, positive ground system, the resting voltage is 6.3 volts and the charging voltage should be about 7.1 volts. The exact charging voltage may be as low as 6.6 volts or as high as 7.1 volts.
Take a multi-meter and set it to measure DC voltage, then measure the voltage across the positive and negative battery terminals with the engine off. On a 12 volt system, a fully charged battery should read a resting voltage of 12.6 volts. After you start the car you should see a charging voltage of about a volt higher than resting voltage. If the reading doesn’t increase by about a volt or if it stays at the resting voltage, it means that the alternator isn’t recharging the battery. This could be because the alternator is defective, the regulator is defective, or the wiring between them has failed. In any case, if you drive the car, the battery will run down. If the battery runs down enough that the ignition stops firing, the engine will stall. It’s really important that you don’t simply jump-start a car with a dead battery without checking to see if the alternator is charging.
A basic charging system health test: Use a multi-meter to measure the resting and charging voltages as described above. Then, with the engine running, gradually increase the electrical load by turning on the headlights and the blower fan. Then increase the engine RPM to about 3500 as you watch the reading on the multi-meter. If the voltage stays about a volt higher than resting voltage, then the car’s charging system is functioning. But if the voltage drops or increases dramatically at any point, there’s a problem with the alternator or the voltage regulator.
